Antec Nine Hundred
Written by Wil Harris
November 21, 2006 | 16:10
Tags: #case #review
Companies: #antec
Internals
Antec Nine Hundred Internals Antec Nine Hundred Internals
Moving inside, the interior is almost comically dull and featureless. The drive bays are mounted down the right hand side with thumbscrews, and there is a 120mm fan bracket over the middle drive bay in case you want even more cooling. The cables to plug in the top ports are tied back with re-usable cable ties. At the back of the case you can see an increasingly rare sight - PCI expansion slots that have screws to attach them. Almost every new case we see has some form of screwless retention mechanism, so it's disappointing to see this being the case.
There are two 120mm fans in the front of the case, blowing air into the main compartment. These both have speed limiters on them that are adjustable, so you can trade off noise against cooling performance.
Here you can see the fan controller and the ATX cables - unhelpfully, these are single pin plugs rather than being joined together in standard plugs for power, HDD LED and so on.
